what power steering pump?
Ford/Thompson 'pencil neck' P/S pump, has a steel reservoir. P/S pressure hose threads onto the pump.
1966/71 FE Passenger Cars, 1967 F100/250 352, 1968/76 F100/350 360/390.
Accessory outer single, double and triple sheave pulleys, bolt to the harmonic balancer to add P/S and/or A/C. 1961/67's use 3 bolts, 1968/76's use 4 bolts.
I'm not sure what type truck you are installing this on but I used an Eaton Pump from a 1957 T-Bird (readily available on eBay as they were used on most vehicles including tractors in the 1950s). I installed it on a flathead V8 so I had to make my own brackets but I'm sure that brackets for a 390 should be much easier to find.
Here is the link to the thread with some pictures.
Toyota P/S box clearance - '50 F-2 V8 - Ford Truck Enthusiasts Forums
There are 4 different types: 900-3A674 - 900-3A674-A/C - 1100-3A674 - 1100-3A674-AC / The 1100's were used with 1958/64 FE engines.
There are two different types of reservoir lids, some are flat, have a tendency to throw fluid out past the dipstick. Some are the turret style (see pic).
On some cars with A/C, the reservoir is remotely mounted on the left fender inner apron.
shotgun2
11-18-2011 08:20 PM
Moremeat
07-05-2008 10:58 PM
dinosaurfan
12-06-2000 10:37 AM
bwrock
06-23-1999 11:48 PM
