Cold weather problems
Received 3,101 Likes
on
Why would that be ? 12v is 12v .?
Volts do not indicate amps. If a relay is old and has "iffy" connections, it can still carry 12 V, but the amperage passing through the relay will be reduced, as some of it turns to heat (in the relay) as a result of poor connection. The old, poor connections at the UVCH may handle that reduced amperage just fine. Then a person installs a nice new relay with great connections, and the amperage delivered to the UVCH is increase, and they are no longer happy.
on
a bad relay can send 12 volts but only 50 amps to the glow plugs through the under cover harness and they will be happy. the glow plugs may not work very good, but the UVCH will be happy.
now put a new stancor relay in the mix, and all of a sudden the UVCH is seeing 12 volts with 150 amps. it will get unhappy very quickly and let out all it's smoke
On a side note... if you've ever seen a smoke test kit, designed for finding air leaks and such. Well, we had a new tech at work and had him actually using one to try to "recharge" the smoke on a relay...
Bird Hunter
01-02-2010 07:14 PM
todd230
01-18-2008 01:38 PM
