I just want to add a subwoofer . . .
2016 crew cab, with the "sony premium" system with SYNC, navigation, steering wheel controls and all that stuff. According to Ford, it doesn't have the subwoofer the "lesser" Sony Premium system has. I found the amp, located behind the passenger side rear seat-back. It's got three multi-wired connectors. The connector with the thickest wires are presumably feeding it its main power and ground - and possibly the pre-amp outs from the head unit.
I want to tap the pre-outs from the head unit, to feed an aftermarket amplifier to power a sub, instead of converting speaker level outputs from this amp into a line-level signal. I'd like to keep all the speakers the way they are, powered by this little silver amp.
I really don't want to remove the head unit, since it controls the heated seats, navigation, SYNC to my phone, and maybe other stuff. I just want to add a (powerful) sub.
Has anyone done something similar who would be willing to offer guidance? I guess I could go prodding around with my bar graph multi-meter, until I find something resembling pre-amp outputs, but I'd have no good way to go about it. I don't want to cut any of these factory wires, if I don't have to - does anyone know where I might find some slick connectors that would allow a clean splice? Any help appreciated, thanks.
Not sure if you have seen this post or not but maybe this will help.
https://www.ford-trucks.com/forums/1...r-upgrade.html
Take another read through the thread, I ended up using the front woofer channels for the sub. The 'Sub' high level outputs are heavily filtered and a poor choice.
Yes there are low level signals, however they are raw and have no volume control or any processing done to them, so not really usable.
Yes you can use a volt meter to find the wires if they are a different color than the schematics I have posted. Good luck
Wish I had more time too, still need to swap out front speakers and build anonther sub level controller. have the stuff just no time
OverHeight
06-10-2011 08:37 PM
ExpyDex
07-22-2005 07:14 AM
RanDawg
02-01-2003 08:49 PM
