Help with a 65 F250 Tire Size
Old 10-09-2015, 12:38 PM
mdelisi's Avatar
mdelisi
mdelisi is offline
All - I'm having a heck of a time finding tires for my 1965 F250 4x2. I tried 235 75 R16 and 235 85 R16 but both look too big for the car (see photo). After researching the site I got these sizes as most recommended them and use them - but maybe that was on the 4x4's. I guess I could do a lift kit here, but I really want to go stock.
And I'd like to get the size a bit fuller (aspect ratio) than the current 225 65 R16's on it (see 2nd photo). I also need to get a truck-rated tire (load range D or E).
Can anyone tell me what the original tires were? Any suggestions on sizes (other than those above) that would do what I need here? Or are we just having to look into a lift kit.
Thanks for the help here!
Mark
Old 10-09-2015, 12:46 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Bias ply blackwalls:
Old 10-09-2015, 02:22 PM
mdelisi's Avatar
mdelisi
mdelisi is offline
Ok that's helpful - but I want to go radial.
Old 10-09-2015, 05:31 PM
Roger Carter's Avatar
Roger Carter
Roger Carter is offline
Slicks weren't offered with radials when new, as ND's post shows.
I ran Michelin radials on a '68 F-250 in the mid 70's. As I remember they were a 7.50 R-16, 8 ply. They were a relatively tall, narrow tire.
Staying with a LT rated tire is going to limit your options as far as sizes. I think your best bet is to go to your neighborhood tire store and let them know what you are looking for.
Good luck.
Old 10-09-2015, 07:27 PM
Mattrod68's Avatar
Mattrod68
Mattrod68 is offline
http://www.tirerack.com/tires/tires....omCompare1=yes
235/70 16 load range xl, 2300 lbs per
Old 10-09-2015, 08:27 PM
6t6merc's Avatar
6t6merc
6t6merc is online now
Like Roger said: 7.50Rx16, tall and skinny, look correct but might not be widely available.
Eric
Old 10-09-2015, 08:32 PM
Mattrod68's Avatar
Mattrod68
the ones i posted also come in 215/85 16 load range e
Old 10-09-2015, 08:59 PM
Thinlizzy13's Avatar
Thinlizzy13
Thinlizzy13 is offline
The rear gear ratio might help you figure out what diameter tire to look for...My 66 F250 has 4.56 gears and 235/85R16's put the speedometer dead on...
I used a GPS and ratio calculator to figure out how off my speedo was and what diameter tire I needed to go with.
Old 10-11-2015, 06:57 AM
mdelisi's Avatar
mdelisi
mdelisi is offline
Thanks all really helpful. I'm curious thinlizzy if you had to lift the truck to fit the 285/85 R16s?
Old 10-11-2015, 07:26 AM
Thinlizzy13
Didn't have to lift it at all. Filled out the wheel wells nicely
But I also have the wide opening fenders up front. I'm not sure if they will fit the normal opening fenders...sorry that isn't really helpful for you, but at least you'll know that they fit the back lol.
Old 10-11-2015, 08:36 AM
mdelisi's Avatar
mdelisi
mdelisi is offline
Is yours a 4x4?
Old 10-11-2015, 11:02 AM
TA455HO's Avatar
TA455HO
TA455HO is online now
F250 4x4 sits up quite a bit higher from the factory as you can see by comparing this picture. They also used the older styleside beds with the different opening. Very easy to tell apart from F250 2x4, which is what the above picture is of.
Old 10-11-2015, 11:14 AM
Thinlizzy13
Yea mine is 2WD
Old 10-11-2015, 04:16 PM
john jamieson's Avatar
john jamieson
john jamieson is online now
For reference here's my '64 F-250 with 7.5 x 16
Old 10-16-2015, 06:11 PM
hoss73ford's Avatar
hoss73ford
hoss73ford is offline
I have not had any clearance problems with 235 85R 16s and they give you a little better gear ratio that a 70 series
Quick Reply: Help with a 65 F250 Tire Size
