Crank Case Pressure is way to high
Tech: How External Vacuum Pumps Free Up Horsepower - EngineLabs
Looking for options on how to solve High Crank Case Pressure
I am getting a lot of blow bye with the new engine . My Oilpressure is very high from the crank case pressure . Oil is being pushed outall over the place .
I was thinking about going this way with it the pan Evacsystem its cheaper and no extra pullies
B&B Performance Crankcase Evacuation Systems 66100 - Free Shipping on Orders Over $99 at Summit Racing
I do not want to go with a Vacuum system I have to hook up to mypulley system I have A/C and there is not a lot of room for a vacuum pump. I have very high flow muffler so flow should not be a problem with the pan Evac .
on
Hmm who built this motor for you. This not a normal condition unless something was assembled wrong. Sounds like the rings did not seat. Were the cylinder honed enough?
Or piston rings installed wrong?
Other things possibility's is a plugged up PCV, or PVC system not being used at all.
And it will never stop blowing oil if engine was assemble wrong!
Orich
Orich
trippn4re
23
06-02-2014 04:16 PM
