Side Mirror help
Side Mirror help
Glad I found this site! 1st post. I recently got a 66 F100. Loving it so far. Im looking to add side view mirrors. I ordered the 5 inch round ones. My truck doesnt have the slots for the mirrors like others do. A reliable recommended body shop in Georgia would be the best route for me I think. I don't think this is something I would want to try myself. Any help on the best way to go about it would be greatly appreciated!Thanks. Pic below.
Glad I found this site! 1st post. I recently got a 66 F100. Loving it so far. I'm looking to add side view mirrors. I ordered the 5 inch round ones.
Open the doors, look inside at the front, you'll see where the mirrors once bolted on.
See parts catalog example...
Welcome to FTE; The mirror bracket is available thru most Ford part supplier's.
Posting link to a couple, as well as other related components:
Mirror Arm | Dennis Carpenter Ford Restoration Parts
Ford - Ford Pickup Truck Outside Rear View Mirror Arm - Bright Finish - Right Or Left - 6 Hole Mount - Macs Auto Parts
Thanx yet again; although, thought OP said he ordered the " 5 inch' round side mirrors. Suggest set the window glass on the bottom of the door and inspect how the Pre-Owner filled in the holes, may be able to remove the plugs; otherwise, may consider returning the mirrors and going another route?
After taking the door panel off, I see where the pre-owner covered the holes. I think I need the measurement from the front edge of the door to where the slot would start. From there I could create a small hole and then be able to look into the door panel to see where I cut out the rest of the hole. it appears to be an inch or 2. Any help on this measurement would be greatly appreciated!
Establishing a reference point can be a challenge. The measurements on my 65:: *Approx. 1/2" down from the 'crease' where the main body of the door meets the vent window portion, this point is to the top of the grommet. *From the hinge side of the door, measured 1 1/2" from the edge, this point is to the center, both at the top and bottom of the grommet. *The grommet measures approx. 1 3/4" length and 7/8" wide. Word of caution, do not cut the opening to the size of the grommet, there is a lip/groove in the grommet the sheet metal opening sets inside of. If you have not purchased the grommets, strongly suggest doing so before tackling the project, should come in handy to use as a template and in determining the exact measurement. *I would probly come down 1" from reference point, and 1 1/2" from the edge to drill the hole; as you mentioned, this should provide a starting point?? Sorry, the explanation does not make any sense to me either?
Junior Junior
04-16-2013 04:49 PM
psycho015m
19
02-28-2010 08:16 AM
