New Headgaskets
Just check BOTH the block and the heads before you throw another gasket and all that work at a problem that will pop back up if the block or head is out of spec.
No gasket should only last two years no matter how crappy it is. You either had bad surfaces or torqueing issues when you put the heads back on last time.
truckeradg86
07-28-2009 02:23 PM
Chris Iverson
05-27-2004 11:14 PM
