1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Play in swaybar normal? Vid included
Old 10-07-2015, 09:49 AM
octaneforce's Avatar
octaneforce
octaneforce is offline
2008 f250 2wd. I was hearing a clattering noise from my front end and low speeds and realized i can grab the sway bar and move it left to right somewhat easily. Is this normal or should i get new bushings?
http://vid153.photobucket.com/albums/s231/islandracer21/Mobile%20Uploads/trim.5CFDB4F9-AFEB-4355-B311-70250B2A8BE1.mp4
http://youtu.be/UGUWGPr8Yd4
Old 10-07-2015, 09:58 AM
octaneforce
Old 10-07-2015, 03:14 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
New bushings and links may be in order for you. Sway bar should be stiff.
Old 10-07-2015, 05:49 PM
octaneforce
I did the end links and it really stiffened it up. I cant seem to find the bushings though. My bar is 1 5/16" but the stores keep giving me 1 1/8" bushings
Old 10-08-2015, 02:55 PM
octaneforce
Its stiffer with new hardware but i can still move it. and i still have a horrible metallic clattering noise over bumps. I think the replacement bushings were alot softer than the originals. Im gonna check out my local speed shop for some universal 1 5/16 swaybar bushings. This noise is driving me up the fkn wall
Old 10-08-2015, 04:08 PM
Bently_Coop
Rockauto.com should have bushings. Otherwise use the part number from rockauto and check the local auto part store. I did this online with Orielly's and found the right ones.
login6696
07-16-2018 03:09 PM
atikovi
06-10-2015 06:06 AM
Chevmn56
20
07-26-2013 08:02 PM
John7894
12-30-2008 06:18 PM
holstein05
04-22-2008 05:37 PM
Quick Reply: Play in swaybar normal? Vid included
