Aerostar Heater Problems
I took my 1996 Aerostar to get a coolant leak fixed. It had leaked down 4 litres+. I noticed the gauge was in the red. ( thank goodness, I saw it ) When I got my vehicle back from the shop the rear heater worked but the front heater didn't. I took it back and they flushed it out to get any air bubbles and now the front heater works and the rear heater doesn't work. Could it be the controls that are faulty. If so, is that very expensive. I'd rather have front heat then rear heat for defrost etc.
Or could it be something else? It's odd that I get one or the other but not both.
Thanks, I'd appreciate any advice.
Hi FordGrrl. Not sure if you posted in the Alberta sub-forum on purpose, but you will probably get more responses in the Aerostar sub-forum.
Aerostar - Ford Truck Enthusiasts Forums
If you're from Alberta, welcome aboard, and if not, thanks for dropping in!
No problem, and welcome aboard! This Alberta sub-forum is pretty quiet, so replies in here may take a while to arrive, but there is a good crew of us locals.
When you have a minute, take the time to put your location into your profile, and also the details of all the fords you own into your signature. The more details you have in those two spots, the easier it is for folks to help you out with specific answers.
joe evans
08-16-2004 08:04 PM
