switch help
Welcome to the forum, rustyfordhibbard!
My experience has been that the resistors burn out due to the blower motor either going bad or being under a heavy electrical load due to the fan/blower running against leaves or other debris that has made its way into the duct work. Has the fan ever made a screeching noise?
It is always a good idea to annually remove the blower assembly [located next to the resistor] and clean out the duct work. There have been dash fires caused by the hot resistor igniting dried leaves.
By the way, the resistor is located in the duct work so that the moving air helps cool the wire coils. The fan high speed bypasses the resistors.
The resistor block is screwed into the plastic plenum under the hood.
The wire coils are inside the plenum with the harness connector facing out.
Most often it is not the coil that burns through, but the little thermal fuse. (Otherwise you would only lose *one* of the intermediate speeds)
I actually replaced my fuse for $0.69 a week or two ago.
johnem
02-09-2007 10:56 AM
johnny_ninja
11-26-2001 07:55 PM
