Window wiper pivots ?
This is the one I bought several years ago (12 volts), I had to remove one dash support if I remember correctly, and if you plan on AC I don't think this would leave enough room. This pic is from the Sacramento Vintage Ford site. There site only shows pivots for 51 and up. Ill cruise a couple sites and post if I can find a 50 pivot. Good luck.
If you need a pivot because of damaged splines Mac"s has this spline repair kit, but other than that I struck out. Hopefully someone will chime in with better news. As you know this site is very resourceful.Ford - Ford Pickup Truck Windshield Wiper Pivot Repair Kit - Includes 2 Splines & 2 Set Screws - F1 Thru F3 & F100 Thru F350 - Macs Auto Parts
Are you using a '50 cab on your '52 truck?
I don't know if there is a difference in the pivots for the standard vacuum systems on either, but there are big differences under the dash. There are braces for the '48-50 radio under those models that prevent using much besides stock without sawing on them. 51-52 doesn't have those braces.
PM MRCMAN58 (Jess). He should have what you need. He just helped me out with my '50 wiper setup and I believe he can help you too.
Yes, I didn`t brace my cab enough when installing new floorboards and the welds pulled it out enough that I couldn`t close doors. Saw a great deal on a 50 cab in Orlando with working doors so I ran down and bought that one. The rest of the truck is almost road ready.
hivolt5.0
48
02-13-2011 01:07 PM
50FordRat
13
02-13-2011 12:42 PM
John - NNY
12-01-2005 08:16 AM
danbo
07-14-2001 05:14 PM
