steering whine
steering whine
2014 crewcab lariat 4x4. Here is the question. This is only when I'm backing
it up and only after putting truck back in drive do I get the steering wheel whine. It sounds as if it is low on fluid. Only last for a seconds or two. Could this be the start of a steering problem or possibly a brake issue? Just throwing
this out there. Any suggestions would be great.
Since you're concerned, I'd make an appointment to have your dealership inspect. It sounds like you can replicate the whine pretty easily; see if you can take your tech on a test drive so you can demonstrate it for them. How many miles are on your truck?
Crystal
Saw from your other thread that you have an EcoBoost truck. If that's still true you don't have a conventional power steering system, it's an electric motor that provides your steering assist. Definitely not low on fluid, but they can still fail. A very pricey fix if you're out of warranty.
Crystal
toocheaptosmoke
11-25-2015 08:17 PM
afonda
1999 to 2016 Super Duty
02-11-2009 05:33 PM
pauls painting
10-12-2008 07:12 AM
