Want to buy a driver's side rear spring carrier and shackle for the 1966 F350
That's the damaged rear hanger. Whoever put this on didn't even put it on right because of the damage. they just welded the top of the carrier to the frame goofy like and used a couple of bolts to also bolt it
. Scary thing is this is a 1 ton dump truck and if this thing fails it would be a disaster
The largest part in the middle of this picture is what I am calling the carrier
EOTZ-5775-D (replaced C6TZ-5775-H) .. Rear Spring REAR Hanger Bracket-attached to frame rail / Right/Left is the same / Obsolete
Applications: 1966/79 F350 except 1974/79 Super Cab & except 1979 4WD / 1980/86 F350 Cab & Chassis.
CLEMONS FORD-LINCOLN in Ottumwa IA has 1 = 800-779-8521.
BOWMAN SALES & SERVICE in Bowman ND has 1 = 701-523-3257.
PARTS INTERNATIONAL in Farmers Branch TX has 1 = 888-727-0418.
COURTESY FORD-LINCOLN in Danville IL has 2 = 217-442-1840.
SUNBURY MOTOR CO. in Sunbury PA has 3 = 570-286-7746.
The same pic is in the 1957/63 catalog, but the part number is different for 1957/60, different for 1961/63, different again for 1964/65, different again for 1966/79 (C6TZ-5775-H).
The C6TZ-5775-H part number was updated/replaced in 1980 by EOTZ-5775-D
LDS: By the power of the Holy Ghost (and the Ford truck parts catalog), ye may know the truth of all things.
5775 is the part you need, despite what it looks like.
Does this bracket also fit on F350 trucks made in the 80's? If so what years?
Ok, so now that I have the hanger off, (the largest part with the 4 bolt holes in it to bolt it to the frame) now I can see that the shackle is also damaged as well as the rubber insert. So basically the whole thing is shot. I called the dealer in Texas that you referred me to and told him I need the shackle (the other metal piece that hooks directly to the spring) as well as the guts of that shackle that have worn out. I told him one of those 4 digit numbers on your parts sheet you gave me but the dealer said that the 4 digit number was only a base number but he needed the whole number. If you could help me with those numbers I'd really appreciate it thanks!
EOTZ-5775-D (replaced C6TZ-5775-H) .. Rear Spring REAR Hanger Bracket / Obsolete
See post 7 for sources.
C5TZ-5776-D .. Rear Spring REAR Shackle / Obsolete
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
B7C-5781-A .. Rear Spring REAR Shackle Bushing / Obsolete
GREEN SALES CO. has 230.
C5TZ-5781-A .. Rear Spring REAR Shackle Bushing / Obsolete
PARTS INTERNATIONAL has 9.
GREEN SALES CO. has 13.
ghunt
11-25-2009 08:13 AM
77460
13
12-03-2008 05:30 PM
