introducing my '54 F100 projec
Old 04-23-2016, 12:35 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
Nice work so far, but I was surprised you did not replace that whole little panel on the inside front cab corner.
Old 04-23-2016, 02:29 PM
toby tough's Avatar
toby tough
toby tough is offline
Looking good, but I don't think the cab will fit in that crate. At least you know where the bad spots are. There is an end to all the sanding and grinding but it is a long way out there for most of us.
Old 04-24-2016, 11:43 AM
seanf100's Avatar
seanf100
seanf100 is offline
interesting to see it coming on ...whereabouts in the UK are you ? ...I have a 53 f100 which I acquired end of last year ....im down by Swindon Wiltshire
Old 04-24-2016, 06:56 PM
Justboy's Avatar
Justboy
Justboy is offline
Will look forward to seeing your progress with that engine and suspension. I've never heard of anyone successfully using anything but the Series2/3 & XJS versions. But where there's a will...
Good luck
Old 04-26-2016, 05:08 PM
jazzydog's Avatar
jazzydog
jazzydog is offline
Good luck
Thanks guys, I am in Hertfordshire. I have a new set of adjustable cab mounts arriving shortly so I am hoping to re aquaint the chassis and cab at the weekend. Then the fun begins as I start dismantling the Jag!
Old 05-20-2016, 03:42 AM
jazzydog's Avatar
jazzydog
jazzydog is offline
I have reunited the cab with the chassis but just resting on blocks of wood for now.
I cut off a couple of the rivets holding the rear spring perch to the chassis, expecting to simply punch them out.... but found they still do not move, I couldnt find my drill, so i had to return to this great forum to find out how the springs are removed, the pins were driven out easily and rear axle was removed.
So now I have the Jag axle roughly in the position it needs to be. If it is fixed here it gives at least an inch of lift, so I am now considering how to modify the frame to give at least the original ride height, but I would prefer an inch or two drop.
All ideas welcome!
I have wrestled the rear axle from the Jaguar, and
Old 05-20-2016, 05:23 AM
jazzydog's Avatar
jazzydog
jazzydog is offline
I only have one question at the moment.... Am i right in thinking that the pinion angle should be horizontal??
Old 05-20-2016, 05:32 AM
jazzydog's Avatar
jazzydog
jazzydog is offline
What plans do you have for yours? I wanted a '53 as i prefer the cleaner front end look, but settled for the '54
Old 05-20-2016, 07:30 AM
Jules The Great's Avatar
Jules The Great
Jules The Great is offline
I think Generally pinion angles point up to the front of the car and the engine should point down a bit.
In reality the angle of the pinion should match the angle of the engine and transmission to keep the system balanced at normal ride height.
Old 05-20-2016, 07:43 AM
Bluey Zedoff's Avatar
Bluey Zedoff
Bluey Zedoff is offline
Looking good, mate.
Are you using the whole Jag for your project or just engine? That engine bay Looks complicated! But lots of fun!
Old 05-20-2016, 08:43 PM
Jules The Great
You could check out the Barbers project as well I think he used a Jag rear end?
Old 05-22-2016, 08:22 AM
jazzydog's Avatar
jazzydog
jazzydog is offline
Thanks, yes that makes sense
  #28
Old 05-22-2016, 08:25 AM
jazzydog's Avatar
jazzydog
jazzydog is offline
Yep, plan is to use all the jag that I can, moving on to the fuel tank next. Fun fun fun!
  #29
Old 05-22-2016, 08:28 AM
jazzydog's Avatar
jazzydog
jazzydog is offline
Cool, thanks I shall have a search for it
bjmayberry2
03-26-2019 10:36 PM
ETOWN55
09-12-2016 10:08 AM
abe
06-08-2016 04:53 PM
albertaphotog
09-06-2011 01:09 AM
fastphil
24
06-21-2010 12:16 PM
Quick Reply: introducing my '54 F100 projec
