Missing and glow plugs not working
Old 10-03-2015, 12:34 PM
jedediah's Avatar
jedediah
jedediah is offline
I have a 97 f250 HD powerstroke that has a miss that I have been fighting for a little bet now and cant find the problem. It started after i replaced the velve cover gaskets because the plugs had gone bad. I also replaced the plugs to. If someone nows whats going on with this i could use a little help. also the glow plugs dont work for crap.
Old 10-03-2015, 01:24 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
If you used Dorman gaskets from the parts house, that's more than likely your problem. And for glow plugs, if they don't say BERU on the plug, don't put them in.
Old 10-03-2015, 01:28 PM
jedediah's Avatar
jedediah
jedediah is offline
I used oem gaskets and its still the original glow plugs. I didnt have a problem with them tell the gaskets had gone bad. now it wont start when its under 40 out side and not pluged in.
Old 10-03-2015, 02:37 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Is the glow plug relay working?
Old 10-03-2015, 03:25 PM
farmert's Avatar
farmert
farmert is online now
Did you solder the new pig tails on, or use butt connectors? If you used the crimp on butt connectors, this may be where the miss came from. X2 on the GP relay.
Old 10-04-2015, 07:02 AM
jedediah's Avatar
jedediah
jedediah is offline
The relay is working. I did sadered all the pig tall ends in.
gummybear918714
04-20-2010 09:59 PM
Diesel Fiend
07-03-2007 12:12 AM
firebug
01-20-2007 09:07 PM
HUNTER10
08-15-2006 09:37 AM
jqp00002
05-02-2005 09:31 PM
Quick Reply: Missing and glow plugs not working
