94 f150 knock sensor
I've had to drill and tap a 5.0 block for the knock sensor. No big deal before you put the engine in.
I've had one with the knock sensor plugged in but with the sensor just sort of hanging around. It never set a code unless you ran the KOEO or KOER tests. Unfortunately the computer won't know to retard the ignition if you run into detonation issues if it isn't mounted properly. So that's sort of a gamble.
