Cylinder head find, bust or a treasure?
Old 05-10-2016, 11:17 PM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
hummm i think i have seen better repairs.. but as far as retapping i would not do that.. that is a heli-coil in there its not tapped for the bolt size but rather the heli-coil's outside diameter
  #62
Old 05-11-2016, 08:03 AM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is online now
Worth a try, or as my granny said just before she fell off her Harley, "sonny, its just crazy enough to work."
I'd gook it up real good with the strongest epoxy you can find and give it a try. Smooth off the outside and get rid of the flux which could get in the lube system.
  #63
Old 05-11-2016, 08:21 AM
Carloespo's Avatar
Carloespo
Carloespo is offline
Smooth it of with an angle grinder and a flap disc? If I use a cut disc to remove the heavy do I risk exposing a fissure in the weld?
  #64
Old 05-12-2016, 06:29 AM
Chip away the flux w/ a chisel.
Contour the outside of the boss with a die grinder and carbide cutter.
If you find a fissure in the weld it will probably fail eventually anyway; hence the epoxy. All that extra braze glop on the outside doesn't add any strength to the repair anyway.
cleatus12r
23
06-23-2019 03:14 PM
Mixer man
24
08-13-2016 04:18 PM
eveblack
Modular V8 (4.6L, 5.4L)
06-27-2016 11:33 AM
ottoparts
03-22-2014 05:16 PM
coolguy1419
05-31-2010 07:39 AM
Quick Reply: Cylinder head find, bust or a treasure?
