OMC 235 302 or 351?
on
Can you post a picture?
The taller deck height of the 351 means the block is physically taller and wider than the 302 and this shows up in a couple easy to see places like the surface where the distributor mounts or the water inlet relative to the head gasket surface. The 351 intake is also about 11" wide while the 302 is only about 9" wide.
drileybond
01-05-2012 06:54 PM
