What problems with putting a newer engine in an older F150?
I have been shopping around for an early 90's, late 80's F150. Found a bunch, but so many of them have pretty high miles on them.
So, I was wondering what perils might I encounter trying to drop in a 2010 302 into one.
I've done one engine swap in my life, but that was a 360 Ambassador station wagon into a 343 Javelin back in about 1979. (I loved that car)
Anyway, that was pretty much a unbolt, disconnect, remove, install, reconnect, bolt up kind of change.
I guess what I'm trying to find is a the newest engine that I can swap fairly easily.
Any ideas?
Any ideas?
I won't discourage you if you really want that modular 302. But do be aware you'll need a trans that will fit it, which means engine + trans swap and then driveshafts will need to be reworked to fit as well.
Motor mounts of course are different. Might or might not have clearance issues with the firewall, exhaust, etc. Remember the mod motors are pretty wide!
You'll also need a standalone engine controller and trans controller if you're going with a slushbox auto. The other choice is to make the factory electronics work BUT they are I think dependent on other modules as well. You will at least need to get the security system working, part of which is integrated in the PCM.
Just do a mild build on a 302/351. Be care of buying a truck that's a speed density truck if you really want to get into the motor, or be ready to do a MAF swap (MAF, 9AL computer, etc), or be ready to go carb. Then, if you still don't have enough "seat of the pants" feel, re-gear it. If you find a zf5 truck, you won't completely kill gas mileage either. 4.10's, mild built 302, zf5, and I think you'll be very happy.
I agree the cost of an older 302 being cheaper than a modular 5.0L, but you know of a 302 that has 385+ hp and gets better than 22 MPG in a truck?
