1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
New Gears for a 5.4
Old 10-02-2015, 10:00 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
I run true 35" tires on my 2V V-10 EX, it has the 4R100 but both it and the 5R110 share the same OD ratio. With my 4.88 gears I turn 2400 RPMs at 70 MPH in OD, the combination of the 35"s and 4.88 gears nets an effective ratio of 4.39. Our Ex is our tow rig, we pull an 11k TT and use OD for 95% of our towing miles without issue. The change from the stock 3.73 gears to the 4.88 was like getting a new truck, the higher RPMs allow the trans to stay in OD at speed while climbing grades. The deeper gears improved our towing mileage from 6.5 to 7.5 MPG up to 8 to 9.25 MPG and only cost me about 1 MPG while running unloaded on the highway. Pickup and drivability is much better (and more fun!) with the deeper gears.
Old 10-03-2015, 08:35 AM
nojoke327's Avatar
nojoke327
nojoke327 is offline
Originally Posted by r2millers
The OP gave me the impression he had a 4r100 when he referred to the tranny shifting "non stop" in and out of Overdrive, thinking he had an OD button, not a tow haul unit.
I know Mark has talked about not necessarily using the tow/haul mode with the 5r110 when hauling or towing, but don't recall seeing his approval of heavy towing in OD with the 4r100.
Would like to re read his thoughts if you have that thread?
The OP has a 2005 and therefore a 5r110w
Old 10-03-2015, 11:17 AM
r2millers's Avatar
r2millers
r2millers is offline
And no Overdrive.
Old 10-03-2015, 04:54 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
And no Overdrive.
If I remember correctly it has 2 overdrive gears. Anything over a 1to1 ratio is a overdrive gear..
Old 10-03-2015, 07:39 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Boy, I wouldn't be towing in OD with that much weight unless it's a tow/haul setup.
When I pulled with my 4r100, i'd usually pull in 3rd and manually downshift into 2nd at about 52 mph to keep it from shifting back and forth. I wasn't comfortable pushing that OD with that much weight.
After towing with a 7k boat and a 10k toy trailer for years, 320k later I'm still crossing my fingers. Changing ATF regularly too.
Originally Posted by Bently_Coop
The 4R100 with OD on is fine. Mark Kovalsky has mentioned that leaving it in OD is fine because of the cooling circuit. Also OD off is really only if the transmission is constantly hunting.
The OP has a 5r110 which is a much more stout transmission.
@Mark Kovalsky some insight on this please.
Old 10-03-2015, 09:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,571 Likes on 1,049 Posts
And no Overdrive.
Why not? What happened to it?
You don't remember correctly.
Both the 4R100 and 5R110 have only one overdrive gear. That ratio is 0.71:1.
4R100 ratios
2.71:1
1.54:1
1:1
0.71:1
5R110 ratios:
3.11:1
2.2:1
1.54:1
1:1
0.71:1
Old 10-03-2015, 09:36 PM
r2millers's Avatar
r2millers
Mark,
I indicated no overdrive because his tow/haul doesn't lock out the 6th gear. The op's original post discussed locking out the overdrive, hence the reason I thought he had a 4r100.
Can you reply and clarify Coop's 13th post about not needing to lockout OD when pulling, because of the cooling circuit?
Old 10-03-2015, 09:39 PM
Mark Kovalsky
No, I can't. I don't remember ever saying anything like that.
I have said that if the trans stays in overdrive without frequent downshifts you can tow in overdrive. The 4R100 trans can cool in either 3rd or overdrive.
Old 10-03-2015, 09:50 PM
Bently_Coop
Thanks for clarifying. I misspoke r2.
Old 10-03-2015, 09:55 PM
r2millers's Avatar
r2millers
Thanks. I guess it goes back to original design as to why Ford would include an OD lockout or tow/haul option.
No reason to add an expense unless there was a value to the customer.
Old 10-04-2015, 10:15 AM
cold_beer839's Avatar
cold_beer839
cold_beer839 is offline
I'd definitely go with 4.88's if you are running 35's, as that's what I run in mine and I've been pleased with it. The 5-Star tuner is great to have as well, because it has towing/eco/performance settings for whatever octane fuel you like to run (plus you can change the tire size setting to get speedo accurate again). I burn 87 octane and leave mine set on the performance setting, it tows just fine there (also have headers, y-pipe, and AFE air intake). Cruising at 55mph the engine hums just perfect at 2k rpm's. It's fairly hilly around here, so I leave my OD off when towing.
Old 11-10-2015, 11:55 AM
Wyldnative's Avatar
Wyldnative
Wyldnative is offline
Have you looked into an underdrive unit? For towing?
  #28
Old 11-10-2015, 02:20 PM
KenRebF-250's Avatar
KenRebF-250
KenRebF-250 is offline
It is a no brainer. Go with the 4.88's.
Due to the fact that we have stock 31.5" tires we went with the 4.30's, but if I had it to do over again we'd go with a 4.88 due to the fact that we're towing heavy about 80% of the annual mileage that our truck is driven.
Given the fact that you're towing heavy much of the time and have 35" tall tires I'd even consider 5.13's. Sounds crazy but towing heavy most of the time with the tall tires I'm thinking 5.13's wouldn't be too much gear.
  #29
Old 11-10-2015, 02:48 PM
TheBigBee's Avatar
TheBigBee
TheBigBee is offline
I ran 5.38 gearing with my 5.4L and 38's while towing my boat around 7K and never had an issue.
  #30
Old 11-10-2015, 03:01 PM
NotURMailman's Avatar
NotURMailman
NotURMailman is offline
I have to agree with all of the 4.88 suggestions.
Mitchellb0509
Modular V8 (4.6L, 5.4L)
04-26-2019 09:52 AM
basecamp
1997 - 2003 F150
21
09-16-2010 07:01 PM
spunks00
10-28-2009 11:30 PM
Viken
12-07-2004 12:45 AM
Bigtruckdriva
11-06-2004 12:52 PM
Quick Reply: New Gears for a 5.4
