lowering the rear end
Guys, I need help. First, I need to say my truck has a Chevrolet rear end so the clearance is a little different than stock. I installed the adjustable leaf spring connector to the front of the rear leaf strings and I installed the dropped connector to the back of the rear leaf spring.
It is still too high by about 1 1/2 ~ 2 inches. I have enough travel to drop here and not cause clearance problems. Can I take a leaf or two from the spring pack and achieve this?
If so, I assume it is just unclamping the pack and removing one or two. Will there be any need to get shorter pins or clamps that line all the leafs up?
Thanks
Thanks
bulldogcountry1
08-18-2017 07:03 PM
jhaas63
69
11-15-2015 08:05 AM
cheappower82
09-16-2003 02:54 PM
