2006 Ford F250 Lariat Crew Cab 4x4 - Cummins
Year: 2006
Make: Ford
Model: F-250
Price: $26000
Mileage: 98000
Color: Green
Private or Dealer Listing: Private Listing
Location (State): TX
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: Green
Engine: Cummins 6.7L
6.7 Cummins Swap
(6.7 block, head, pistons, crank, & injectors -- 2006 Common Rail 5.9 accessories)
98k miles on truck, 12k miles on motor since rebuild
EFI Live custom tune, Borg Warner S363 turbo, ARP headstuds, AirDog 165, 12v rods, pyro boost & trans temp gauges
48RE auto transmission, billet triple disk torque converter, manual shift NV271 Ford t-case
Very clean interior, grey heated leather front buckets w/ console, leather bench in back, power sunroof, factory brake controller, factory radio & cd player
ARE color matched fiberglass camper, spray in bedliner, smoked taillight side marker & cab lights
Almost new 35x12.50x18 Mastercraft Courser MXT, new brake rotors & pads all around
Truck is in very good condition, motor pulls hard and smooth. Almost no black smoke, only a little bit just before the turbo spools up and then none after that. Idles and runs great. Built to be a daily driver and tow monster, not a diesel hot rod. All wheel bearings and ball joints were recently replaced as well, it rides as good as a ¾ ton truck can. I really like this truck but it's more truck than I need for my towing duties right now. I have way more than 26k in this truck, but I need to downsize. Thanks for looking!
Pictures are here
