0 MPG, by the gas gauge.
Driving on a very unsmooth patch of pavement my gas gauge went from 3/4s to below empty and the check engine light came on with the code P0643 and hasn't moved off of empty after burning some of that gas and refilling and bouncing around on the farm. Did my fuel level senator unit completely die or is there something like a broken wire I should look for???? I don't have enough time to drop the tank to replace the sender unit at this time of year I'm in the field, farming and it's going to suck not having the fuel gauge working as I can burn a ton of fuel pulling wagons and stuff and require refilling almost daily or use almost no fuel at random intervals....
06 f350 V10.
06 f350 V10.
I replaced Dads fuel pump assembly on his 00 when the pump quit and would assume and hope it would be as easy to do on mine, i'm fairly certain that sender is the problem now as after driving without a gauge and filling every 150 miles (just to be safe on fuel) the fuel gauge will start working for a short time around 3/4s of a tank. I dumped and a can of seafoam on the current tank of gas with no expectations of it helping and so far it hasn't, if there's any miracle cleaners that can fix it that would be awesome but pretty much planning on replacing the unit and incredibly annoyed at the timing ....... Dads fuel pump had the consideration to die when we had nothing better to work on.
