track bar question
Old 09-27-2015, 10:28 PM
Eaglescout94's Avatar
Eaglescout94
Eaglescout94 is offline
track bar question
I installed X code springs on my 2000 F350 and bought an adjustable track bar to center my axle. Everything went together without a problem until I tried to install the new bar, its too long. The stock bar appears to be to long as well; axle is pushed toward the passenger side. Any ideas what could be going on? On the plus side the new x codes ride alot better than the worn out v codes.
Old 09-27-2015, 11:01 PM
glockholiday's Avatar
glockholiday
glockholiday is offline
How far off is it?
On my 05' Excursion I had my track bar off to weld a crack in my track bar bracket and couldn't get the track bar back on. It was only a half inch off though. I used a ratchet strap to pull it back over so I could get the bolt through.
Old 09-28-2015, 06:55 AM
Eaglescout94
It looks like the axle is around a half inch, maybe more towards the passenger side. I got everything bolted up but I couldn't figure out how the factory bar was too long
Old 09-28-2015, 09:23 AM
jetdoc's Avatar
jetdoc
jetdoc is offline
Mine did the same thing....I fiqured it wasn't wise to force the springs over, something will eventually break.
FordF350Baby
09-09-2020 09:42 PM
Bigblue351
05-23-2012 11:56 PM
JTyler11688
01-08-2009 09:14 AM
jaye
03-03-2008 06:29 PM
69 F100 4x4
09-12-2002 11:40 AM
Quick Reply: track bar question
