Revising post..Not stale gas.. it's some sort of exhaust leak but..
Old 09-27-2015, 09:23 PM
Hankster1958's Avatar
Hankster1958
Hankster1958 is offline
It's not the EVAP canister.. it is exhaust.. Took wife for a ride.. (i'm partial tone deaf) and a sound i barely heard when under load.. SHE says IS REAL AUDIBLE.. sort of like pinging.. but the wrong tone, and not as "fast"... forwards, reverse.. no difference. Does not do it when simply revved.. has to be under a load..
Idles great.. runs smooth.. just this goofy sound & smell in the cab . Did rag in tailpipe test at idle.. no change.. she could not hear it do it.
91 F150, 5.0.. AOD... any ideas what could make such a noise, and leak an exhaust smell, but not be heard when not under load, or with a rag in the pipe?
I WAS able to get it to do it a little at a standstill.. by "brake torquing" it lightly..
Anyone? Where do I look??
Old 09-27-2015, 09:26 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Exhaust - Manifold leak. Can sound something like knocking or pinging.
Old 09-28-2015, 12:26 AM
Hankster1958
ok, if i have a leak at the exhaust manifold...can this cause the o2 sensor to read wrong, and it run rich?? My MPG has dropped, and the exhaust does smell too rich now.
Old 09-28-2015, 02:39 PM
Hankster1958
Found it... it's where the EGR line goes into the lower intake manifold... used a shop vac to pressurize the exhaust system... and that's where it's hissing out of...
same question.. can a leak here, cause it to run richer than normal??
Old 09-28-2015, 05:02 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
Yes, it definitely will.
Old 09-28-2015, 05:29 PM
Hankster1958
Great! Thanks, that's what I needed to know. part 's been ordered.. funny how fast you can remove the Upper plenum the SECOND TIME...after having done it a day before .. LOL!!! thank's again
Old 09-28-2015, 05:42 PM
rla2005's Avatar
rla2005
rla2005 is offline
Yes sir, experience is everything and so are freshly excercised fasteners. I could pull the upper intake on my old '92 F250 w/5.8L engine in 15 minutes after the initial R&R.
Old 09-28-2015, 06:25 PM
anthonym92's Avatar
anthonym92
anthonym92 is offline
Lol around the 3rd time i did it i felt like a badass mechanic. Now i know everyone can do it so my manliness went down the drain haha
Tmill
1999 to 2016 Super Duty
03-07-2011 01:09 PM
stroken
04-09-2008 09:09 PM
aocabrown
12-17-2007 09:06 PM
mrwizard
1978 - 1996 Big Bronco
01-02-2003 11:15 AM
Quick Reply: Revising post..Not stale gas.. it's some sort of exhaust leak but..
