problem with c6 shift pattern seems to be backwards
ok thank you 1320stang
I got the lever off but I cant rotate as far forward as the one in the picture about. I can only rotate to about where the bolt hole is for the natural safety switch or flip it down below the pan as it will the transmission housing. ran out of time to try to get it back together but may try later tonight or tomorrow
the number on the lever is D8TP-BA does any one know if this is the right lever thanks
Here's a pic of my C6 from a 77 f150 351m. The shift lever when pushed all the way to the rear puts the trany in park. It seems like you could point your lever up, push it to the rear, disconnect your linkage put the shift lever in park then adjust and reconnect the linkage. That's the way I did mine and it shifts great. Good luck with it.
its ok that its upside down. I believe that I have figure out that I need the linkage like what you have. does the rod connecting to your transmission run straight up or does it connect to the frame.
I believe I have one like fuzzybob but I need the one like yours 1320stang. If you can could you see if you can find a part number on it. I have talk to a couple of people and they have told me that the number I posted earlier was for 1980 and later trucks so I was wondering if there is a difference in the part.
Sorry, I only saw this today. Mine is 2wd, and I'm almost positive it goes straight from the column to the trans, but I'll confirm.
It would seem maybe you're missing a bell crank. Lets see if I can make this work:
...........( O )
Ignore the dots. The equal signs are the rods, if you pull on the top one, the bottom one pushes and visaversa. You could be missing that I guess, but I have no ida.
...........( O )
#30
Click on the two links below and you can see the two different setups.
