dually swap
dually swap
Hi all. Few quick questions looking for some input on swapping to a f350 driveline. Truck in question is a 95 f250. It has a mildly built 351w. I rebuilt it with .030 over pistons, crane 444232 cam, rebuilt set of gt40 heads, 1.7rr, long tube headers and a custom exhaust. I also rebuilt the e4od with heavy duty parts, b and m stage 1 shift kit and a deep aluminum trans pan.
We were given a 94 f350 4x4 idi that ran but the frame was rotted and the body was falling apart. I want to swap in both axles and convert my f250 into a dually.
Question:
Should i use my springs on the front and rear? Looks like mine has 2 more springs and a 4 leaf helper rather than the stock single spring.
How do you think the 351w will do towing heavier loads? I know it's no torque monster, but it's probably close to a dying 460.
Should i do the shackle flip/reversal in the front and rear?
This is just going to be my tow vehicle, mainly cars and trucks. Very rarely will i tow heavy equipment, but i do on occasion.
Question:
Question:
F350 front springs(solid axle) are different than F250(TTB)
Also a small black sing is rated less than the Big block/diesel spring
Rear springs came as 4 leaf and 5 leaf. The F350 only got 5 leaf, F250 came both ways.
351s are pretty much the sam HP as a 460 just a little less torque, but yours is mildly built so you should do just fine
it depends how much lift you are looking for
Question:
Ok so my rear spring pack has 6 leafs and an after market helper spring pack. Looks like someone may have added a leaf. I did not know the springs for the front were different. Do i need to swap the hangers as well? or are they in the same location as the F350?
I really am not looking for much of a lift as i will be using this truck to tow. i thought i read somewhere that doing the shackle reversal in the front improves the ride quality. Idk it was just a thought in my head as i was getting a parts list together to do this swap.
mando jake
15
04-27-2009 09:50 PM
carm_scaffidi
13
04-30-2005 07:40 AM
