400 Rebuild Round 2
Old 11-02-2015, 07:39 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Originally Posted by dimora
Two things here:
1) Tim Meyer is the best guy to go to for the parts you need on these engines. I bought nearly everything from him. He will match Summit and Jegs. I did not waste his time. I saved my money until I was ready to pull the trigger, then I called Tim, e-mailed him my specifics, and waited for him to call me back. When he called back, I wrote down the questions I had and he helped me make good decisions for my build. I respected his time and gave him my business and money.
In return, he gave me great advice and when I was shimming my Scorpion roller rockers and checking my roller-on-valve stem alignment and calculating rod length, Tim Face-Timed with me (in real time) on a Saturday so I got it right. Now THAT is personal customer service like I have never seen before from any vendor! Bear in mind that I bought my stuff from him and did not dis-respect him or his time by asking him to help me but not giving him business.
If we want to keep small businessmen like Tim operating and available for all of our benefit, we need to support them with our wallet. It is worth the slightly longer wait vs. shopping at the big box stores, and you make a friend in the process.
2) On the ignition topic: Either stay 100% DuraSpark, or go with a COMPLETE aftermarket setup. Do NOT try a GM HEI ignition or a distributor with built-in ignition control...they lack adequate discharge power vs. the DuraSpark and they are not reliable.
I tried an MSD Pro Billet all-in-one and could not figure out why the car would die at idle, sputter on shutdown, ping on acceleration, and run like crap after my epic rebuild. It was the lack of quality ignition spark. I added the MSD digital ignition box and all was well. It runs great now...but my point is now it runs as good as the OEM DuraSpark system ran!
The advantages in going aftermarket are the good looks, billet parts, easier curve-advance and timing stop bushing changes, and multiple-spark discharge, but it is costly. So either stay 100% OEM or go all-in if you go aftermarket. I have not used Accel, Mallory or others, only MSD, but that is my experience.
Shane
Amen!
  #77
Old 11-02-2015, 11:52 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Thank you for supporting Tim, Shane; reps for that!
  #78
Old 12-13-2015, 05:51 PM
HVACTOM's Avatar
HVACTOM
HVACTOM is offline
Update.. still saving . Finally got heat in garage. Still no decision on what to do about the heads.
  #79
Old 12-13-2015, 08:05 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Save up and do it right.
  #80
Old 12-13-2015, 11:39 PM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
HVACTOM,
The question about heads begins with this... "How much power do you want to make?"
  #81
Old 12-14-2015, 01:44 AM
HVACTOM's Avatar
HVACTOM
HVACTOM is offline
Not really wanting a ton of power. Would it be nice? Yes but the primary use of this truck will be to drive a few hundred miles up north every now and then. I want better compression and do not want to waste money on rebuilding my heads. I'm leaning toward the aussie heads. I also will be buying tims pistons his low end ones and I don't know if they are compatible with the aussie head's. Honestly what ever is cheaper and will be reliable and realistic for my needs.
  #82
Old 12-14-2015, 11:41 PM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
The good news is that Tim can get you squared away no matter what you decide! He's done the Aussie heads and I think he's still got a special piston for them, as well as stock 351M/400 heads and all kinds of aftermarket aluminum ones too.
  #83
Old 12-15-2015, 11:29 PM
HVACTOM's Avatar
HVACTOM
HVACTOM is offline
Yeah after reading around I decided to just get mine professional references done. From what I see , they are just fine for what I need. I just couldn't get over the thought of putting that amount of cash into them smog heads. But I already have them and they are straight not warped just need probably valves and valve job , removal of smog bumps. If the cost gets up there I'll add tims rebuilt heads to my order. I will get a quote tomorrow for valve job and if needs guides, and all that good stuff.
  #84
Old 02-18-2016, 11:06 PM
HVACTOM's Avatar
HVACTOM
HVACTOM is offline
Well finally got the heads in the shop and hopefully getting them back soon. Next steps are pistons then gasket kit. Been a long and busy winter for the hvac biz here in the big city.
  #85
Old 02-19-2016, 07:42 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Busy is good?
  #86
Old 04-20-2016, 04:01 PM
HVACTOM's Avatar
HVACTOM
HVACTOM is offline
So what's up with that piston price increase? I just went to his w3bsite to finally buy them and I don't remember them costing that much.
  #87
Old 04-20-2016, 04:15 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Dunno. Bought mine a year ago so hadn't noticed. Maybe Keith Black increased the price of making them?
  #88
Old 04-20-2016, 08:29 PM
HVACTOM's Avatar
HVACTOM
HVACTOM is offline
Who knows, looks like the crap o lites will be going back in.
TetelestaiWY
04-28-2018 08:34 PM
OldSchoolRodz
06-25-2008 11:43 PM
fomocoguy3
01-27-2008 04:41 PM
nvogt59
21
08-29-2003 08:19 PM
Quick Reply: 400 Rebuild Round 2
