few basic questions on 1983 f-150 project - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Old 09-26-2015, 03:04 PM
cubanice27 cubanice27 is offline
cubanice27 is starting off with a positive reputation.
Hey all!! I just bought my first project truck. Its a 1983 f-150 v8 302.
I know most trucks with carburetors have a heater tube. My truck does not have one right now, HOWEVER every picture of every RE-MANUFACTURED carb that shares the same carb tag number as mine (e3te-ava) has some sort of extra "tube" like object coming from the carburetor. (see pictures below) So do you think mine should have a heater tube? Did mine snap or break off?
Ive read multiple threads on here about heater tubes and how it should look.
Also, I wanted to replace my choke thermostat. Some thermostats have a few screws to undo and the thermostat comes off. On my carb, there are 3 studs that look like they were made to be tamper proof. Is this the case? Can I drill out these screws and later replace them with others? (see picture below)
Thank you for your time and appreciate any help I can get!!
you can see inside a little bit. look at picture above. See the difference? Im missing that tube coming off. What is that for??
snapped off heater tube? No gold nut or threaded parts....
Here is the tamper proof nuts. Can I drill these out and replace them so I can change out my choke thermostat?
Inexpensive Compression Test Tools (right to the point) Tugly 1999 - 2003 7.3L Power Stroke Diesel 21 02-14-2017 05:26 AM
Cool stocking stuffer 66with352 1961 - 1966 F-100 & Larger F-Series Trucks 5 01-01-2017 03:57 PM
Back-Up Camera Fifty150 Transit Connect 0 11-06-2016 07:25 PM
few basic questions on 1983 f-150 302 v8 cubanice27 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 09-27-2015 12:41 PM
What are these? AlanMac 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 09-08-2015 12:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
