Have 83 F800 8.2 Detroit. I was given p/n E0HZ-2B574-C for tube assembly. Who has 1 in obsolete inventory? This may not be the correct p/n but that's what parts guy give me.
1980/83 F/FT600/800 8.2L Detroit Diesel with 6M, 7M or 9M front axle with or without P/S
Or, do you want the P/S pressure hose?
1983 F/FT600/800 Detroit Diesel, the following is required to get the correct P/S pressure hose, as there are two possibilities.
I need the AXLE code printed on the Certification Label and the production date, also printed on this label at the upper left or right corner.
Im looking for line from P/S pump to steering gear box. The info on incomplete vehicle sticker is not readable. The mfg date is 3-83. vin DPK84NXDVA26350. Which side is axle weight stamped in axle. Would this help?
I need the AXLE code from the Certification Label because there are two different P/S pressure hoses (P/S pump to gearbox).
The 3rd digit of the axle code, when decoded lists the weight capacity of the front axle. Certification Label glued to the left door face below the latch.
VIN doesn't help and what you typed is wrong because you omitted the first 2 digits. VIN contains 17 digits, not 15.
EOHZ-3A719-B .. P/S Pressure Hose (Pump to Gear) 8.2L Detroit Diesel / Use with 5,500 lbs. capacity front axle / 1980 F600/800 from 9/80; 1981/84 F600/800.
E3HZ-3A719-P .. P/S Pressure Hose (Pump to Gear) 8.2L Detroit Diesel / Use without 5,500 lbs. capacity front axle / 1980/82 F600/800; 1983 F600/800 before production date 12/83.
NOTE: May not need all this BS! Look at the old hose on the metal portion just before the rubber portion is swaged to it for an ID number. EOHZ-3A719-B is marked EOHT-3A719-CA
