Grounds and things.......
Old 09-25-2015, 03:26 PM
econolinemanor's Avatar
econolinemanor
econolinemanor is offline
Lightbulb Grounds and things.......
I've been seeing TSBs for ground issues because of painted up contact points on some of the newer cars, so I checked out my 02 E150 and 2010 Fusion ground points and both of them were painted up pretty good too. So long story short, two fresh Motorcraft Batteries and cleaning the paint off the ground points on both of them and they have never run better or smoother, even the Trans shifts better in the Fusion..............
Old 09-26-2015, 05:20 AM
JWA's Avatar
JWA
JWA is online now
Received 1,393 Likes on 1,102 Posts
Striving for paint-free ground connections is great---just be advised there's another side to this, namely unprotected bare metal. Ideally you'd establish a solid ground connection that's permanent and then completely encapsulate the connection at the body/frame with a rust/corrosion inhibiting compound or material.
Old 09-26-2015, 07:23 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
The manuals used to suggest vaseline or grease. NO-OX-ID is another commercial product that is supposed to be conductive as well.
Old 09-26-2015, 10:57 AM
econolinemanor
I used Dielectric Grease on the Van and Car, I also pulled a lot of Connectors apart and gave them a dab of it. It took me about three hours on each one just cleaning and messing around washing the Engine bays down, Air Filter Boxes, cleaning out the water drains, my coffee breaks, then a long Test Drive so the Computers could Re-Learn, I had a good day.................
Old 09-27-2015, 04:32 PM
tx2sturgis's Avatar
tx2sturgis
tx2sturgis is offline
Thumbs up brush it on...
Liquid Tape works pretty well for this...
sportinh2o
26
02-03-2009 08:13 PM
alconk
11-16-2008 10:05 AM
SportCustomWalt
Paint & Bodywork
09-07-2007 04:31 PM
stewards68
19
04-26-2007 08:04 AM
924x2150
12-27-2003 10:21 PM
Quick Reply: Grounds and things.......
