Starter "clicking"
Starter "clicking"
This is my first vehicle that I had to turn the key and push a button to start. Not to tough to get used to, but, I was wondering, should I still hear the "clicking" after the vehicle has started? Or, should a relay kick off and stop that? Seems to start hard the 2nd time through, as if the battery has been drained by the starter "clicking".
OK, I assume that the attached is the solenoid. It "clicks" before starting and then continues to "click" after truck has started. You mention that maybe something is grounding out. Now could it be because the PO has redone the system to be a negative ground and not the original positive ground? I'm guessing that I have quite the chore ahead of me.
allisonmo2
03-12-2009 08:52 PM
