Stainless Steel Manifold Studs
Has anyone put stainless studs in for the manifolds? i'm considering it when i put on the new manifolds but have heard good and bad. It makes sense to use stainless for its resistence of oxidation at high temps, also stainless has less thermal exspansion in comparison the carbon steel. So is anyone running stainless manifold studs or bolts?
I used stainless steel bolts and washers when I did my exhaust manifolds probably 13 years ago now. It was around the same time I was sick of fighting all the rusted parts and I used ss brake lines, and ss hardware to hold the brake and fuel lines, etc.
Then I parked the truck and now only drive it in the summers.
But I see no reason not to use ss hardware wherever you want.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Nate is spot-on. SS is good to use but if you over tighten them and they gall you're screwed. (pun intended) You can buy some anti-galling compound to help reduce the chances of galling.
For your reading pleasure:
http://www.fastenal.com/content/feds...%20Galling.pdf
dthut
03-16-2017 10:50 PM
