i have an 88 f150 with a 300 i6 and it wont idle below 1000 rpm, even with the idle screw all the way out. anybody have any clue whats wrong? thanks,
mike
I would guess that your distributor has turned, or more likely you have a vacuum line loose or off. I had a vacuum line off on my 460, and it would idle @ 1000-1100 rpm, found the leak and idle returned to 550-650
