The Surge
I have had very few automatic transmissions in my lifetime, so I know less than I suppose I should. This one's a C-6. When I start the engine in the morning, shifter in the Park position, I often feel a very slight, very short tendency for the van to try to move forward. Why?
Have you discussed this with your Ford Dealer? I recommend doing so. You may locate one (and schedule an appointment online, if needed) here.
What's the model, year, and current mileage of your ride?
Todd
Wait a minute, isn't the converter full of fluid and turning its output shaft all the time, running the pump all the time? If the valve body is in the Park configuration, why would there be any gears meshed to apply any torque to the driveshaft? Is the viscosity of the fluid such that it can actually impart a little torque to the transmission output shaft? If so, why is the effect I tried to describe only felt for a little less than one second? Or could this have anything to do with the bands or their adjustment (only one in a C-6)?? This probably sounds like I'm trying to argue with you, but I just need more explanation. If it's the converter, is this effect dependent on whether it's a lock-up type or conventional converter? (What I NEED to do is hunt for an animated drawing of an automatic transmission, and quit asking you to hold my hand! I'm nearly as old as you, Stuart, and should have taken more interest in automatics just as a matter of being mechanically-educated).
on
Ford Transmission Forum:
Yes the convertor is full of fluid and turns whenever the engine is running. There is an impeller inside that does not turn until engine RPM is increased. This impeller is connected to the input shaft which is splined to the forward clutch drum. The surge is only momentary. Next time start the vehicle in Neutral and see how far you get. The only time a transmission will drive for any distance in Neutral is if a clutch pack was seized. Which in your case is not because every other gear works. Above is a blow up of a C6 transmission.
https://www.google.ca/?gws_rd=cr&ei=...nverter+images
on
Like I mentioned fluid is a tad thicker on a cold start but thins out very quickly.
