I have a 97 f 150 with the 4.2 bad miss on # 6 changed plugs and wires still missing. Also have a bad tick and exhaust smells like fuel. Check engine light is blinking. HELP!!!
Misfire, smells like fuel, CEL blinking!
Sure it all goes together when fuel is being passed into the exhaust unburnt.
Have you thought about replacing the coil and checking the coil connector?
Good luck.
Ok, the last cylinder on the driver side.
It is a secondary side failure from the coil tower, plug wire or the plug.
Only other possibility is injector failure or cylinder mechanical fault, blown head gasket.
Your missing it some where.
Good luck.
