1993 f150 hazard light...
ok soo.... my flashers work but the hazard lights dont. when i press the hazard button the flashers stop working.... so ik it isnt the switch, other than that i dont know what it could be unless it could be a fuse, but i checked all of them... any help is appreciated
yeah ik where the flasher piece is, but i cant find anything in my service manual about it or how to fix them. :/
I just read up on this, I guess I'm quite a few years behind...LOL The E-flasher is on the backside of the fuse block and they said it can either be directly behind the TS flasher or on the other side of the block, so I'm guessing you have to unbolt the fuse block and flip it over to replace the fuse.
You don't need to unbolt anything. Just stick your head up under the dash near the brake pedal and look at the backside of the fuse panel. You'll see the flasher there. Just yank it out and install a new one. I replaced mine about a year ago and I didn't unbolt anything.
I have occasionally had problems with the flashers (4 ways) on my '96 especially after sitting for a few months. I just turn them on and off rapidly quite a few times. Apparently the contacts on the switch get dirty or slightly corroded. Cycling the switch rapidly cleans them up and then they work like they should. Ive also had the same problem with the turn signals and windshield washers........same solution for those as well.
