what the??!!
what the??!!
So we bought a new to us 04 Escape for the kid, he loves it! My question is, what's going on when I accelerate somewhat aggressively, the tach and speedo peg high and battery light comes on. It does not affect performance and gauges return to normal within a couple seconds. Any insight is appreciated! Thanks
I would check for bad wires that are stretched or moved by the engine moving on the engine mounts. Also check for ground cables from the engine to the body/cab which could be jumping around under acceleration.
You are losing power or ground, and possibly the gauges are pegging because they are carrying the current needed to run any accessories or the ignition, instead of a normal feed of power/ground through a wire or cable.
tom
tom
It ain't a ground problem. The gauges are "resetting" because their supply voltage dropped and then came back up.
The alternator will likely test as "good" just to **** you off, but, as I said, the brushes are unable to keep in contact with the contact plates at the higher RPMs. At lower RPMs they work just fine.
I used to see this all the time on the 3.0 and 3.2 SHO engines which were high-revving by nature.
Got to your local Walmart and pick up one of these: Equus Innova 3721 Battery and Charging System Monitor - Walmart.com It will make it a lot easier to diagnose.
fordf11948
05-31-2018 04:22 AM
351Cleveland C4
02-24-2016 10:52 PM
DIRTYSTEVEN
02-26-2008 11:55 PM
