Fuel Line Routing 1958 F100 223
WOW... Thanks much. I appreciate the photos. You guys are great!
The reason I am replacing the lines is because I keep having problems with fuel pumps. The first one started leaking after a few hundred miles, so I figured bad pump and replaced... second is doing the same thing. I know there are 2 different pumps, one for electric wipers and one for vacuum and I have double checked that. Might be just bad luck, but this time I will replace the lines as well.
Thanks again!
Thanks again!
It shouldn't make a difference which pump you have. The only difference between them is the vacuum wiper pump has a booster section for the vacuum line to the wipers. If you look at the lower photo, you can just see the blocked off ports on my pump. I switched to electric wipers and haven't changed the pump yet. Where are the pumps leaking? I would also check the flexible hose from the chassis to the pump. That's a very common place for a leak, especially after you've disturbed it during a fuel pump replacement.
Lou Manglass
Lou Manglass
Does it still have the braided hose with fittings or have you fitted a piece of regular hose with barbed ends and hose clamps. If it has the braided, get rid of it. There is also another piece at the fuel tank. Also check the flare fitting for the output to the carburetor. It doesn't take much wrong to make one of those leak.
Lou Manglass
Lou Manglass
FordsOnlyGarage
11-17-2018 08:43 AM
The Momma
03-12-2009 10:40 AM
sweets64f100
04-10-2004 06:57 PM
