With Autoenginuity, can you shut the injectors off individually on a 7.3?
With Autoenginuity, can you shut the injectors off individually on a 7.3? Trying to determine the cause of a white smoke/unburnt fuel at idle issue without pulling the injectors and having them bench tested. I did a Google search but couldn't come up with a surefire answer, don't want to drop the $350 on the software if its not going to do what I need. Thanks!
It won't shut off the injector, but it will look at the Cylinder Rotational Velocity and conduct a buzz test on each hole. If you have a partial or full misfire at idle, the CRV will show a discrepancy in the time it takes for a cylinder to advance the cam. No matter what scan tool you buy, it can't perform the function of an injector breakout box on a 7.3L - the command is not available in the PCM/IDM. We are stuck with using some old-school (and sometimes rather clever) techniques for troubleshooting specific issues on the engine.
In your case, a Cody test might be the first call when you don't have a scan tool - that would be a good search here on the forum. I have the "classic" AE v10, and it has helped me on countless occasions to find many woes - including a broken #7 wire in the valley two days ago. It took me 5 minutes to find the root cause of the problem after hooking up AE.
Never heard of a injector breakout box before, looks interesting and should accomplish what I am looking to do for a fraction of the price. Thanks for the tip!
MONAVIERONJON
11-18-2014 09:38 PM
036.0stroke
11-08-2012 07:45 PM
