6 port selector valve to 3 port selector valve
Old 09-21-2015, 07:11 PM
bullnose1985's Avatar
bullnose1985
bullnose1985 is offline
Hello All,
Started working on my 1985s fuel tank switching problem. I would switch to the rear tank and the level wouldn't register. The 1985 is a 6 port 5 pin selector valve.
So i went and Pulled a tank selector valve off a 1980. A much simpler 3 port 1 wire.
Since i intend to use the 1980s engine, tilt wheel, and eventually the wiring harnesses. Until i switch the cabs is there a way i can wire and plumb as well vent the front and rear tanks? From a 1985 6 port 5 wire to a 1980 3 port 1 wire.
Old 09-21-2015, 08:08 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
No, I would ditch all the valves and run just on one tank. You will need to figure out the wiring at the 6 port valve also, the 6 port valve also switched the sending units from tank to tank. It's more complicated than you think, your diesel needs a return fuel line from the engine, that's why it uses a 6 port valve.
Old 09-21-2015, 09:26 PM
bullnose1985
Hi Dave, So if i understand the wiring diagrams correctly the 6 port selector valve switches the tank from front to rear regarding to the fuel gage input. I may start on the 80 wiring harness.
Any ideas on plugging the returns comming from the fuel tanks?
Old 09-22-2015, 06:51 AM
Franklin2's Avatar
Franklin2
If you are going to use a engine setup that does not need the fuel returns, a short piece of hose with a bolt in it slid onto the return line at the sending unit would work well enough.
All diesel engines need the return line system, and most factory 460 setups used a return line system.
Old 09-22-2015, 08:46 PM
bullnose1985
Thanks Dave, I pulled the wiring harness that goes from the fire wall to the tail light plug. I will start on wiring the 85 from rear to front.
Do you by chance have any experience with bullnose era tilt wheel key cylinder removal?
Old 09-22-2015, 09:19 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Old 09-22-2015, 09:41 PM
bullnose1985
Originally Posted by ctubutis
Thanks ctubutis!! That's should be everything needed. Wow that's great information!!
Fummins
25
12-28-2016 09:24 AM
rterril02
11-20-2016 01:12 PM
newrevnorton
10-30-2016 01:25 PM
NeverFinished
08-06-2013 11:10 PM
KLSimpson89
02-11-2013 09:00 PM
Quick Reply: 6 port selector valve to 3 port selector valve
