4R100 dead after 255k
Old 10-12-2015, 12:56 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Originally Posted by Nicmike
I don't have first hand experience with swapping out valve bodies on an older, more experienced transmission, but I have heard others say they replaced the torque converter AND valve body on older transmissions and kept them going for lots more miles without rebuilding the tranny. I would think replacing both would be a must, since the single disc, stock TC is what is most likely to put you in the market for a new tranny (like mine did). I didn't tear mine apart to check the clutches and steels inside, but it was shifting just fine up until the day the TC went out and killed it. I feel strongly (after reading a lot about trannies and the experience of others) that if I would have changed that TC a couple of months ago, or even last year, my tranny would still be going strong right now. It is one of those things that can only be realized with hindsight though, unless you are very proactive and have some extra $$$ laying around...
Thanks Mike, you indirectly answered a question I had about my trans given that the torque converter would be too easy to get to with the engine out.
I'll be replacing it this Spring along with either a transgo tugger HD2 or JWVB.
  #92
Old 10-12-2015, 02:28 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Yeah, torque converter could be replaced by a monkey trained to listen for three "thunks" while turning and pushing in on an object Way too easy to do if you still have a weak stock converter in there. When mine was properly seated (and after I got three "thunks"), it was about 1/8" away from touching the fly wheel with the bell housing tightened down. Putting the new nuts on "sucked it up" to the fly wheel and closed that little gap.
  #93
Old 10-12-2015, 11:46 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Just don't forget to fill the converter first
  #94
Old 10-13-2015, 12:20 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by Toreador_Diesel
My 7.3 will look like that come spring
why would you wait tell spring? it cant be weather related, as its always nice enough to work on your truck in texas.
  #95
Old 10-13-2015, 12:24 PM
Toreador_Diesel
Retired Mod
Spring time + Tax Time = $$$$$ required for the parts I need.
  #96
Old 10-13-2015, 12:30 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i knew it had to be somthing other then weather! around here its weather & money that decides it. i use the weather as an excuse to be lazy, when i was living down in arizona, it was 24/7 working on stuff, but i really do enjoy it. sometimes i need to drink a beer as a motivator now a days.
  #97
Old 10-13-2015, 12:57 PM
agsmv1's Avatar
agsmv1
agsmv1 is offline
I wish I got enough back to do anything...probably owe again!!
racecar13
03-03-2015 07:39 AM
tubolove
06-09-2008 04:50 PM
mrgomerpyle
02-11-2006 03:12 AM
anton19
04-15-2004 11:07 PM
Stiers
05-19-2002 11:51 PM
Quick Reply: 4R100 dead after 255k
