1998 5.4 motor wont stay running
Old 04-18-2014, 10:55 PM
strokermax's Avatar
strokermax
strokermax is offline
Got a buddy with a 98 white f150 with the 5.4 motor. It will start up & idle fine but if you try to drive it it has no power what so ever.
If you can give me some ideas of what it could be?
Old 04-19-2014, 01:24 PM
thzpcs's Avatar
thzpcs
thzpcs is offline
Are you sure it's the motor, or could it be a tranny issue? Is it auto or manual?
Old 04-19-2014, 01:25 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
In this order,
Check for codes,
test fuel pressure for being in the 30 to 40 psi range.
If nothing found, it's time to put a Scanner on and look at live data for the problem. It will show some where in the data.
Don't replace parts trying to hit it until something is showing as faulty.
Good luck.
atvracer557
08-31-2016 09:00 PM
96max2fast
1997 - 2003 F150
01-01-2012 06:22 PM
jspec
2004 - 2008 F150
13
12-29-2011 09:49 AM
99EX44
1997-2006 Expedition & Navigator
10-17-2001 10:09 AM
Quick Reply: 1998 5.4 motor wont stay running
