79 ford f 250 starter trouble
got a 79 f250 with a rebuilt 400 with approx 15k on it
all this trouble started when i discovered i had a cracked flywheel.
I put a brand new flywheel on it and also put a new starter and new solenoid on it at the same time.
hooked the battery back up tried to start it and acted like battery was low just clicked. checked to make sure everything was connected properly and tried again with same result.
So i jumped the solenoid and it was very noisy like a old chevy that wasnt shimmed right.
got it started and drove it then parked it went out later to start it and just clicked again.
put a new battery in and same thing so tried to jump solenoid again and rolled twice very noisy and would roll just got the starter wire hot
I pulled the starter to find the gear split and was missing a tooth.
I thought at first that i was given either the wrong flywheel or starter but i do have the correct flywheel and a 9 tooth starter
Why am i having this problem before i replaced the flywheel i had none of these problems
I m stumped does anyone hav any ideas?
on
Powerstrokin7.3L
10-10-2012 11:35 PM
desperado_18_2000
02-16-2004 07:06 PM
