T18 close ratio gears
Did not find this question asked before. I know the T18 came with close ratio 4:02/2.41/1.41/1.0 gears and it was used in various other makes of vehicles besides Ford. I have spent about 3 days on the phone and researching on the net and have not found a T18 with these or the gears to rebuild mine with. For some reason they are not easy too find.
Is there a cross reference I can use to find the parts between makes? Has anyone ever done this? I realize most would rather have the granny gear but the other gears are way too far apart for the mountains around here and I like to downshift slowing the vehicle down especially when pulling a load.
I found a T19A with the correct gears but won't work with the TC.
1979 Bronco 400M
1979 Bronco 400M
Are you sure you have a close ratio T18?
I've never seen one listed for Ford, and after some searches on the net, I still haven't found any reference to one. The close ratio was put in jeeps and stuff, but not Ford (according to what I can find). The Ford's always got the deep granny 6.32 1st.
Thanks for the reply
Oh okay, that makes sense. I misunderstood. I thought you were trying to repair yours.
Sorry I can't help you with more info. Good luck!
I can see a close ratio being useful if you never need the granny. Makes for a nicer daily driver, due to having 4 gears you can use daily, instead of 3.
WHT00EX
10-28-2008 11:37 AM
