7.50-17 on Widowmakers VS. 235/85R 16 on 8 lug Ford Steel Wheel Picture Comparison
I don't recall whether your F-350 is SRW or DRW. Either way it has the 6 lug x 7.25"'pattern. If your truck is SRW and has the 17" widow makers used from 1955 to 1966, the very same rim replacement solution described above for the F-3s will also work on the SRW F-350s. The reason for this is the "semi-drop center" design of the widow maker that has the same center disc diameter as required by the new tubeless 17" "drop center" rims. Stu
collinft
09-13-2016 10:45 AM
Roger T. Pipe
06-14-2015 05:42 PM
53ford
03-27-2009 09:27 PM
