Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F800 steering presure line
Old 09-17-2015, 07:37 PM
fivestarmmd's Avatar
fivestarmmd
fivestarmmd is offline
Have 83 F800 8.2 Detroit. I was given p/n E0HZ-2B574-C for tube assembly. Who has 1 in obsolete inventory? This may not be the correct p/n but that's what parts guy give me.
Old 09-18-2015, 05:57 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Is this what you want?
E0HZ-2B574-C .. Brake Booster Pressure Hose Tube Assy / Marked: E0HT-2B574-BA / Obsolete
1980/83 F/FT600/800 8.2L Detroit Diesel with 6M, 7M or 9M front axle with or without P/S
Or, do you want the P/S pressure hose?
1983 F/FT600/800 Detroit Diesel, the following is required to get the correct P/S pressure hose, as there are two possibilities.
I need the AXLE code printed on the Certification Label and the production date, also printed on this label at the upper left or right corner.
Old 09-18-2015, 07:45 PM
fivestarmmd
Im looking for line from P/S pump to steering gear box. The info on incomplete vehicle sticker is not readable. The mfg date is 3-83. vin DPK84NXDVA26350. Which side is axle weight stamped in axle. Would this help?
Old 09-18-2015, 08:24 PM
NumberDummy
I need the AXLE code from the Certification Label because there are two different P/S pressure hoses (P/S pump to gearbox).
The 3rd digit of the axle code, when decoded lists the weight capacity of the front axle. Certification Label glued to the left door face below the latch.
VIN doesn't help and what you typed is wrong because you omitted the first 2 digits. VIN contains 17 digits, not 15.
EOHZ-3A719-B .. P/S Pressure Hose (Pump to Gear) 8.2L Detroit Diesel / Use with 5,500 lbs. capacity front axle / 1980 F600/800 from 9/80; 1981/84 F600/800.
E3HZ-3A719-P .. P/S Pressure Hose (Pump to Gear) 8.2L Detroit Diesel / Use without 5,500 lbs. capacity front axle / 1980/82 F600/800; 1983 F600/800 before production date 12/83.
NOTE: May not need all this BS! Look at the old hose on the metal portion just before the rubber portion is swaged to it for an ID number. EOHZ-3A719-B is marked EOHT-3A719-CA
Old 09-21-2015, 08:07 PM
fivestarmmd
F800 steering pressure line
Went looked at this units mate. Had Incomplete Vehicle sticker readable. Last charcter is N These were special ordered for state as had 6 digit DSO.
Old 09-22-2015, 05:41 AM
NumberDummy
All 1981 and later VIN's of vehicles sold new in the US have 17 digits, doesn't make any difference if they're special ordered or not.
cmo
Large Truck
08-20-2016 11:26 PM
mpokoney
Large Truck
08-03-2015 12:08 PM
F&M
07-23-2013 04:38 PM
bleedin'blue
Large Truck
04-08-2012 01:22 AM
dablack
07-07-2009 01:44 PM
Quick Reply: F800 steering presure line
