pressure testing hpo system
Old 09-17-2015, 12:35 PM
2004_6.0 powerstroke's Avatar
2004_6.0 powerstroke is offline
Just a quick question, when testing the hpo system when you put air to the system and say my standpipes are leaking will i be able to hear the leak from the stand pipe? will it really be noticeable that it is a standpipe problem. by the way this truck is a early build 6.0 powerstroke so it has the straight oil rails.
Old 09-17-2015, 12:54 PM
navistarnut's Avatar
navistarnut
navistarnut is offline
The real fun begins when realize how long arms come in real handy hooking the air hose up to the ICP port on the early builds.
What are the symptoms that you suspect the stand pipes? Not sure but I don't think the early builds had a lot of issues with stand pipes. That said it's going to be easier to pinpoint things with the vavle covers off if you hear noise coming thru the filler tube or the CCV hole.
Any readings you can post up?
Old 09-17-2015, 07:27 PM
hard starting when hot. sometimes fires and dies other times it can work its way up to a start. like a rolling start. i have other posts with data on the truck, im not sure if you can just click on my name and find my other posts or not.
duste
10-19-2016 04:46 AM
maxum96
08-31-2016 01:01 PM
bigbubba87
01-02-2009 09:48 AM
jahildeb
1997-2006 Expedition & Navigator
12-27-2006 08:28 PM
JWill
Aerostar
06-14-2004 03:50 PM
Quick Reply: pressure testing hpo system
