Sector shaft
Sector shaft
Anyone happen to know where I can buy a sector shaft for a 78/79 F150/Bronco steering box? Any aftermarket upgrades out there? I couldn't come up with anything, obviously not much demand for something like this.
Mine is kind of broke a little. I would also be interested in purchasing a complete used box. Not interested in a new box, I will be converting to full hydro steering soon
D8TZ-3304-A .. Draglink / Obsolete ~ Available NOS & from autoparts stores
1978/79 F150 4WD (except Super Cab) & Bronco.
Upper Bronco pic: Right end (in pic) of draglink (3304) is shown connecting to Pitman Arm.
Lower pic of steering gearbox: 3575 is the sector shaft.
ND see the front axle link set up, hydraulic bump stops, high steer, cross over, high angle heim fittings.....no need to try to school him, just let him know if you can locate the part he needs.
lucky he means well, his application can be very different. As far as locating a shaft, maybe from wcb? I can not believe you can not locate a box in a JY somewhere in all of Washington. Or maybe Redhead would sale just a sec shaft? http://www.redheadsteeringgears.com/
West Coast Broncos
West Coast Broncos
http://www.wcb4x4.com/tech/rcshopman1.pdf
West Coast Broncos
West Coast Broncos
The following users liked this post:
1977/79 F150 4WD / 1978/79 Bronco.
FEYER FORD in Edenton NC has 1 = 252-482-2144.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 136 = 606-787-5293.
D7TZ-3575-B .. Sector Shaft-Use with P/S / Obsolete
Look at using a Spedi-Sleeve to possibly repair it.
D7TZ-3575-B Sector shaft
Thanks for the reply, I’ve emailed FEYER FORD and am currently awaiting a reply.
GREEN SALES CO. Website indicates they are out of stock on the part number search.
WESLEY OBSOLETE PARTS is no longer in business.
I purchased and installed the Spedi-Sleeve for the shaft size, SKF 99818. The seal spacer ID is too small and the seals are way too tight so I pulled it back off.
I tried Blue Top Steering, Tom’s Off-road, NOS Parts Ltd., also with no luck. Hopefully someone else has encountered this and can chime in with another source for the part.
Red Head steering? https://redheadsteeringgears.com/
Lares? https://www.larescorp.com/product-ca...steering-gears
Seen a few on Ebay, good luck.
I bought one last summer from Redhead. New is $300.00, Good used is $250.00, which is their core charge for a complete steering box.
Christina Elliot (800) 808-1148 or orders@redheadsteeringgears.com
Something that will snap them is excess lift using up all extra movement range in the ball joint of the drag link, so when the suspension stretches out like in rebound after a dip, the long drag link with axle on one end and truck on the other end, snaps something when the ball joint runs out of movement room. Might not happen the first time, but soon, it will.
I remember way back in the day, when I needed a new manual steering box for my bronco. Brand new from the local Ford dealer was $175.
Year or so later I bought a sector shaft from the same dealer just to refurbish the other box. Just the sector shaft cost 275!
This was back in about 1980 or so.
Still, price aside, I was glad they had both of them in stock when I needed it.
