1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Interior lights wont come on
Old 11-04-2016, 06:33 PM
spuck77's Avatar
spuck77
spuck77 is offline
I have a 2012 F250 and am having a problem where the interior lights wont come on with the dash switch or when the doors are opened. I have confirmed that it is not a bad fuse, also the lights will come on when the switch on the individual lights is manually pushed, but not automatically like they are supposed to. I dont see it being a door switch issue because the door chime comes on and the stereo goes off when the doors are opened after turning the ignition switch off. I've read that the dealerships will switch out the BCM. I thought maybe the dimmer switch next to the headlight switch but there is no power to it whatsoever, which also I can't dim the instrument panel lights. So, has anyone else had this issue? What did you do to resolve? Thanks in advance!
Old 09-10-2017, 05:10 PM
Racer5349's Avatar
Racer5349
Racer5349 is offline
I'm having this issue now on a '12 F350. I've confirmed also that it's not a fuse or door switch. I'll be following along here.
Old 10-12-2020, 10:38 PM
ZieglerFord's Avatar
ZieglerFord
ZieglerFord is offline
Did anything come of this? I’m having this issue.
2012 f250 with same issue. Done lights work if individually pushed but don’t come on with door. The control button by headlights has power (or at least there is a light on). Can anyone say which relay to check? There looks like only one in the Cabin fuse panel. More options in engine bay.
Old 10-16-2020, 10:25 PM
spuck77's Avatar
spuck77
spuck77 is offline
Having the same problem as well. I first noticed them not working about 5 years ago. I've checked & replaced all fuses and relays that I thought could possibly be the reason. Havent changed out the dimmer switch because it will still dim the dash lights. I will be following as well, hopefully someone will have a solution. It seems to me that a recall should be done by Ford
Old 03-24-2021, 03:14 PM
notafordman101's Avatar
notafordman101
notafordman101 is offline
2016 F250 super duty 6.2
Turned out to be fuse 12 on the truck I just worked on. Fuse LOOKED fine, but did not have power on both sides. This is the fuse box on the passenger kick panel. Hope this helps someone else. Don't trust the fuse even if it looks good.
sumbuddyloanmea.10
11-15-2014 04:18 PM
micmopar
03-29-2009 07:27 PM
c_tripps_2k
2004 - 2008 F150
04-12-2008 05:41 PM
zoomx2
08-28-2004 01:04 AM
wlenglish
03-23-2003 01:23 PM
Quick Reply: Interior lights wont come on
